zerologic Posted June 13, 2006 Report Share Posted June 13, 2006 When i use the window wash on my B6 A4 it sprays water on the screen the wipers make one sweep up then really slowly sweep down again untill they stop and stick about 3/4 the way down the screen and stick there for a good few minutes. Anyone else had this? do i need new blades or is the problem something else? Cheers in advance! Link to comment Share on other sites More sharing options...
UBM Posted June 13, 2006 Report Share Posted June 13, 2006 Sounds like the motor? Link to comment Share on other sites More sharing options...
zerologic Posted June 13, 2006 Author Report Share Posted June 13, 2006 I was hoping someone wasn't going to say that!!! Sounds expensive Link to comment Share on other sites More sharing options...
paul_tdi Posted June 13, 2006 Report Share Posted June 13, 2006 HI Do they work ok on the noraml wiper functions when not using the washers as this could eliminate the motor but as to what it could be.... a module somewhere that is faulty! Sometomes the mechanisms can sieze up causing problems. Good luck! Paul Link to comment Share on other sites More sharing options...
zerologic Posted June 13, 2006 Author Report Share Posted June 13, 2006 on a normal wipe they make a very slow down sweep but normally make it down to the start position. If i lift the wipers off the screen as if i were cleaning the screen by hand and work the wipers they seem to move ok when not in contact with the screen? Link to comment Share on other sites More sharing options...
P_G Posted June 13, 2006 Report Share Posted June 13, 2006 Perhaps they are bent out of position? I had that on a car where they were to close to the screen and the friction was stopping the wiping action. Otherwise or the restraining bolts on the wiper arms are loose. Upwards fine, downwards doesn't work. Link to comment Share on other sites More sharing options...
zerologic Posted July 17, 2006 Author Report Share Posted July 17, 2006 ok so they now seem to have stopped working all together!! Even when they are lifted off the screen the just sit there! Im guessing it's the motor maybe?? Its not too bad at the moment as its so dry but i can see myself getting stuck in a thunderstorm sooner or later. Anyone had this before? looks like a trip to the garage soon i think! Link to comment Share on other sites More sharing options...
P_G Posted July 17, 2006 Report Share Posted July 17, 2006 Not of my car but a former G/F had this on her fiesta and it was the motor that went. Get in the garage quick, thunder storms forecast for the end of the week! Link to comment Share on other sites More sharing options...
zerologic Posted July 17, 2006 Author Report Share Posted July 17, 2006 got it booked in for thursday... so hopefully no rain before then!!! The workshop at my local Audi specialist said it sounded like the linkage maybe seized causing the motor to struggle or the motor itself is seized? hopefully i won't need a new motor and a bit of WD40 will do the trick (wishful thinking on my part i think!) Link to comment Share on other sites More sharing options...
