Suz84 Posted July 20, 2006 Report Share Posted July 20, 2006 Hey All, I have an Audi S3 and am now looking to get a dump valve for it. I want it to sound really good and reasonably loud. Can anybody recommend the best one? I have been told not to buy a Baileys dump valve, and I have heard Turbosmart are good. Please help. Also, will it cause any harm to my car by fitting a dump valve? Thank you Link to comment Share on other sites More sharing options...
DHA Posted July 20, 2006 Report Share Posted July 20, 2006 Yes it will harm your car. Dump valve not required all it does is make a whoooosh noise that Escort turbos have. Link to comment Share on other sites More sharing options...
bustwell Posted July 20, 2006 Report Share Posted July 20, 2006 This is what you want http://cgi.ebay.co.uk/Hyperboost-Diverte...1QQcmdZViewItem Link to comment Share on other sites More sharing options...
s4_sat Posted July 20, 2006 Report Share Posted July 20, 2006 linky no worky Link to comment Share on other sites More sharing options...
Cupramax Posted July 20, 2006 Report Share Posted July 20, 2006 Vent to atmosphere (whooshy) DV's wont work with the 1.8T, it will throw up engine management lights or make it run like a pig if you fit one. As above you need a recirculating type Bailey, Forge and Hyperboost make these, an induction kit will help if you want to hear the woosh. From experience Forge are very good with excellent customer service and backup. http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0105&product=FMCL007P Link to comment Share on other sites More sharing options...
Phil84afc Posted July 20, 2006 Report Share Posted July 20, 2006 Dump valve on an S3!?!?! Surely not... Link to comment Share on other sites More sharing options...
EssFour Posted July 20, 2006 Report Share Posted July 20, 2006 [ QUOTE ] Hey All, I have an Audi S3 and am now looking to get a dump valve for it. I want it to sound really good and reasonably loud. Can anybody recommend the best one? I have been told not to buy a Baileys dump valve, and I have heard Turbosmart are good. Please help. Also, will it cause any harm to my car by fitting a dump valve? Thank you [/ QUOTE ] Please mate don't do it. Dump Valves are pointless look at me pieces of equipment and as stated before will effect the performance of your car in a detrimental way. DON'T DO IT Link to comment Share on other sites More sharing options...
Wallachie Posted July 20, 2006 Report Share Posted July 20, 2006 If you fit a dump valve you should be ashamed of yourself! Go buy a VXR Astra and fit one..... Link to comment Share on other sites More sharing options...
doogal1972 Posted July 20, 2006 Report Share Posted July 20, 2006 NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!! Link to comment Share on other sites More sharing options...
colly Posted July 20, 2006 Report Share Posted July 20, 2006 Effect performance? how do you get to that conclusion? If mapped or even in standard form a decent valve will help the gear changes and help keep the boost on ready for the next gear. I got to this conlcusion by running tests with the standard one and a baileys, in a golf 1.8T and A3 1.8T. I love all the negativity on here when someone is intrested in a product - if the TSN members don't approve youre sure to be made out to be a chav, you must consult the oldies first Link to comment Share on other sites More sharing options...
EssFour Posted July 20, 2006 Report Share Posted July 20, 2006 [ QUOTE ] you must consult the oldies first [/ QUOTE ] Now listen here young man . DV that dispense excess spool pressure to atmosphere are not suited to the ecu. When they dump the air making that lovely whoosh noise the ecu see's that the pressure has dropped and potentionly thinks there is a problem and can possibly go into limp mode. this was pointed out by other posters. If the dump valve, atmospheice, were that good why didn't they fit them as standard. Lecture over from a not so oldie. Link to comment Share on other sites More sharing options...
colly Posted July 20, 2006 Report Share Posted July 20, 2006 I actually run the standard one still. The 'whoooosh, tisss' noise I get comes from the Carbonio, and I being reminded I'm driving a turbo every gear change I make Link to comment Share on other sites More sharing options...
Paul Posted July 20, 2006 Report Share Posted July 20, 2006 Dump to atmosphere valves, are not well suited to the S3. 1. The existing system is designed for a recirculating Diverter Valve. 2. The ECU sets the fueling up knowing what air is in the system, as its been measured on the intake through the maf. Dump this measured air,it can sod up the fueling, and cause fault codes/limp mode. 3. They can actually hamper performance, as whilst the diverter valve is venting back into the system, its helping keep the turbo spun up, and reducing lag, for when your back on the power. A Dump valve which Vents it to fresh air, is counter productive. 4. Those that have fitted dump valves usually have to relocate them to get them to work (in their still ineffcient manner) this means non standard engine bay, more joints and cut pipework, with potential for more boost leaks. 5. A less technically argued point, they sound crap and are chavish. Link to comment Share on other sites More sharing options...
colly Posted July 20, 2006 Report Share Posted July 20, 2006 Yes forgot to mention 'normal' valve won't cut it on the 1.8T, a re-circulating one will not have the bad effects mentioned above. Original poster: Either way let me know which one you get (if you do), how it sounds and how it performs. Link to comment Share on other sites More sharing options...
salem_p Posted July 25, 2006 Report Share Posted July 25, 2006 I have a chipped A3 1.8T of which i am the fifth owner. Owner number 2 had the car chipped. Owner number four had a non-standard dump valve fitted. When I took the car to MOT it failed the emissions test. Only when a standard dump valve was fitted that my car passed its MOT. I was also told that the Dump valve ruined my air mass meter which had to be changed! My advice stick to the standard dump valve! Link to comment Share on other sites More sharing options...
NiGhT Posted July 25, 2006 Report Share Posted July 25, 2006 You dont have to stick to a standard diverter valve you can get a performance one but the only real benefit over the standard throw away plastic part is that it can be stripped and serviced. The confusion here stems from them being banded about as dump valves ie. a valve that dumps air. This is no good for an S3 and is what makes the whoosh noise. The S3 is set up for a diverter valve. A performance Diverter valve that as the standard part recirculates the air is A OK! This wont really give you the sound you desire either though and as somebody said your better off with an induction kit if you want bangs and whistles.. Link to comment Share on other sites More sharing options...
blix Posted July 25, 2006 Report Share Posted July 25, 2006 i dont believe it. whatever next Link to comment Share on other sites More sharing options...
Paul Posted July 26, 2006 Report Share Posted July 26, 2006 Upgrade to a better diverter valve by all means (i have) but it wont get you what you want, ie the chav noises. they dont improve performance either, unless the one it replaces is knackered. they are just a more robust part, that can be taken apart, inspected and serviced. The oem ones are plastic fantastic and just get binned. Link to comment Share on other sites More sharing options...
colly Posted July 26, 2006 Report Share Posted July 26, 2006 Link to comment Share on other sites More sharing options...
