patently Posted July 27, 2006 Report Share Posted July 27, 2006 [ QUOTE ] Looks like he drive's a left hooker. [/ QUOTE ] My lips are sealed.... Link to comment Share on other sites More sharing options...
peterb Posted July 27, 2006 Report Share Posted July 27, 2006 [ QUOTE ] As most speedo's over read I always add a bit on for luck !! [/ QUOTE ] As I've said elsewhere, I always use the GPS-derived speed displayed on the RoadPilot. Link to comment Share on other sites More sharing options...
peterb Posted July 27, 2006 Report Share Posted July 27, 2006 [ QUOTE ] I have to say that a mate of mine went through a 60 limit at 70-75 (open road) and recieved nothing its been well over 6 months too. - sheer luck if u ask me. [/ QUOTE ] Do you mean in the M25 variable limit area? Is he sure that there was a camera on that particular gantry? I don't go south of the M4 very often, but between the M4 and M40, there's only one gantry in each direction equipped with cameras. [ QUOTE ] Does anyone know how the cameras on the variable speed limit section actually work? does the speed setting get re-set at each different speed limit? (daft question I know but would like a proper answer) [/ QUOTE ] Yes, the trigger speed of each camera is set according to the limit displayed on that gantry. I understand that there are various 'safeguards' built in - for example, the camera is inactive for 15? seconds after a change in limit, and there are cameras monitoring the gantry displays. Link to comment Share on other sites More sharing options...
patently Posted July 27, 2006 Report Share Posted July 27, 2006 [ QUOTE ] As I've said elsewhere, I always use the GPS-derived speed displayed on the RoadPilot. [/ QUOTE ] Only accurate on level ground, sadly. Link to comment Share on other sites More sharing options...
JamesB Posted July 27, 2006 Report Share Posted July 27, 2006 [ QUOTE ] [ QUOTE ] My old commute down the A40 had exactly this problem. The camera could be pointed in either direction yet you could see from miles away which way it was facing - [/ QUOTE ] Is that the one at the Uxbridge turn off? If it is I know what you mean... I get passed those with 75 on the clock. Not brave enough to go any quciker especially with a slightly larger rolling radius than the standard wheels [/ QUOTE ] Just that one - I don't tend to go any faster than an indicated 70. I don't think it has much to do with bravery, more wanting to keep my license clean Link to comment Share on other sites More sharing options...
Philbes Posted July 27, 2006 Report Share Posted July 27, 2006 "Mine is +13%....100 on speedo = 87 on Road Angel." That is not +13% its +14.9%. Car is doing 87mph speedo reads 13mph more, so the error is 13 in 87, not 13 in 100. Link to comment Share on other sites More sharing options...
RedRobin Posted July 27, 2006 Report Share Posted July 27, 2006 Thanks for the correction to my maths, Phil. I just read the Road Angel anyway - The rest is academic. Link to comment Share on other sites More sharing options...
pritesh Posted July 27, 2006 Author Report Share Posted July 27, 2006 [ QUOTE ] [ QUOTE ] I have to say that a mate of mine went through a 60 limit at 70-75 (open road) and recieved nothing its been well over 6 months too. - sheer luck if u ask me. [/ QUOTE ] Do you mean in the M25 variable limit area? Is he sure that there was a camera on that particular gantry? I don't go south of the M4 very often, but between the M4 and M40, there's only one gantry in each direction equipped with cameras. [ QUOTE ] Does anyone know how the cameras on the variable speed limit section actually work? does the speed setting get re-set at each different speed limit? (daft question I know but would like a proper answer) [/ QUOTE ] Yes, the trigger speed of each camera is set according to the limit displayed on that gantry. I understand that there are various 'safeguards' built in - for example, the camera is inactive for 15? seconds after a change in limit, and there are cameras monitoring the gantry displays. [/ QUOTE ] So if i understand this right..then each time the speed changes in the variable section of the M25 from say 60 to 40..there is a trigger that sets the camera to the new variable speed? So as a simple test..im guessing it would sit on a database of somekind with an oracle trigger or something more advanced...so I wonder how much time delay there is in the tigger taking affect... ? Link to comment Share on other sites More sharing options...
