Muppet Posted July 27, 2006 Report Share Posted July 27, 2006 I've been unhappy with the radio reception on my RNS-E for sometime, mostly on Radio 2 which has always had a strong signal in all my other cars. Anyway, i have had bad reception, and today i noticed that when i unplugged my mobile phone from the cigarette charger the reception got a whole lot better ! (note, the reception interference was not from the signal of the phone, as this was the case even with the phone turned off) So it would seem that my radio is picking up interference from the electrical systems in the car, Is there anything I can fit inline with the Radio to try and clear this ? (its a RNS-E that myself and CraigyB fitted, so I cant really ask the Stealer) Link to comment Share on other sites More sharing options...
Muppet Posted July 30, 2006 Author Report Share Posted July 30, 2006 mmm 46 views and no ideas ? I was thinking some sort of suppressor in line with the power feed to the radio, ill have a search around the net if no one here has any ideas.. Link to comment Share on other sites More sharing options...
peterb Posted July 30, 2006 Report Share Posted July 30, 2006 So, it's probably the charger which is generating the interference. Is reception still bad if you leave the charger plugged into the lighter socket, but with the phone disconnected? Rather than messing with the car wiring, I wonder whether it's worth trying some L/C supression installed in the charger itself (if you can get into it), or building a short extension lead with supression built in to that. Perhaps the simplest solution is to try a different charger? I have my phone charger permanently connected (below the centre console) and have never been aware of any untoward effect on the RNS-E. Link to comment Share on other sites More sharing options...
PetrolDave Posted July 31, 2006 Report Share Posted July 31, 2006 I'd agree with peterb - it sounds like there may be a switching regulator in the phone charger which is generating the interference. That could be conducted (through the car wiring) or radiated. Either way I wouldn't mess around with the car wiring - I'd try a different charger. Is your charger sold by the phone manufacturer or is it a third party one? Link to comment Share on other sites More sharing options...
