bencole45 Posted July 28, 2006 Report Share Posted July 28, 2006 Just bought a DVD player to feed the AV input for my RNS-E (B6 S4) It's going in the boot, where can I get a switched live power feed from? Any help would be appreciated. Link to comment Share on other sites More sharing options...
shark_90 Posted July 28, 2006 Report Share Posted July 28, 2006 Um.. I have a switched live in mine but I didn't put it in. I think it's direct from the fusebox which would require a fair length of wire and it would be an arse to do.. if no one else comes up with anything give me a shout and I'll trace the wire and find out exactly where it comes from Link to comment Share on other sites More sharing options...
bencole45 Posted July 29, 2006 Author Report Share Posted July 29, 2006 Thanks Shark, I looked at that and just wondered whether there was anything easier. Link to comment Share on other sites More sharing options...
timps Posted July 29, 2006 Report Share Posted July 29, 2006 If you want to use a relay you can take a switched live off the amp in the right hand side of the boot (check with a volt meter Audi have a habit of changing colours) on mine it was white and will run a relay but not power anything more. By the way this wire stays live when the ignition is on whether the radio is on or not Link to comment Share on other sites More sharing options...
bencole45 Posted July 29, 2006 Author Report Share Posted July 29, 2006 Thanks timps....how do you get to the amp? Link to comment Share on other sites More sharing options...
bencole45 Posted July 31, 2006 Author Report Share Posted July 31, 2006 Checked out the wiring on the amp, don't fancy splicing into that. Shark....any more info would be great, I've ground to a bit of a halt here. Link to comment Share on other sites More sharing options...
