Yeatshome Posted July 29, 2006 Report Share Posted July 29, 2006 What tyre pressures are people running? On a R32 MKIV mine came back from my dealer at 28psi is this right? Link to comment Share on other sites More sharing options...
helfinger Posted July 29, 2006 Report Share Posted July 29, 2006 i tend to put about 32 in all round...on std tyres Link to comment Share on other sites More sharing options...
Sugarj Posted July 29, 2006 Report Share Posted July 29, 2006 It tells you what pressures to use on the fuel cap opening. I think its 37 for the front and a bit less for the back. Quite high though! Link to comment Share on other sites More sharing options...
Skidmark Posted July 29, 2006 Report Share Posted July 29, 2006 38 front & 34 back....[up a little on std] turn in & balance is good for std set-up cheers Link to comment Share on other sites More sharing options...
Yeatshome Posted July 29, 2006 Author Report Share Posted July 29, 2006 Yep...many thanks I found it on the fuel filler cap. It is a little higher than other cars I've owned. Many thanks for the quick replys... Link to comment Share on other sites More sharing options...
v6tas Posted July 29, 2006 Report Share Posted July 29, 2006 [ QUOTE ] What tyre pressures are people running? On a R32 MKIV mine came back from my dealer at 28psi is this right? [/ QUOTE ] It depends on what is written around the outside of your tyre wall. There will be some numbers there: Mine reads the following 225/40Z/R18/88Y.......If you open your filler cap then match the tyre wall number to whats written there you will be spot on. For 2 persons mine equates to the following Front tyres 2.5/250 Back tyres 2.3/230 Hope this helps Link to comment Share on other sites More sharing options...
v6tas Posted July 29, 2006 Report Share Posted July 29, 2006 On reading the above quotes for peoples tyre pressures i cant see where you get such high numbers from? If im missing something can you let me know Link to comment Share on other sites More sharing options...
xscreamsuk Posted July 29, 2006 Report Share Posted July 29, 2006 On the Mk5 it's up around the 40 PSI mark. I did a run with passengers and luggage and IIRC it was 3.2 bar. Link to comment Share on other sites More sharing options...
R32Ash Posted July 29, 2006 Report Share Posted July 29, 2006 [ QUOTE ] On reading the above quotes for peoples tyre pressures i cant see where you get such high numbers from? If im missing something can you let me know [/ QUOTE ] I might be missing something about what you're possibly missing , but 2.5 bar = 36psi so it's not that far off what's being quoted, is it? Link to comment Share on other sites More sharing options...
v6tas Posted July 29, 2006 Report Share Posted July 29, 2006 [ QUOTE ] [ QUOTE ] On reading the above quotes for peoples tyre pressures i cant see where you get such high numbers from? If im missing something can you let me know [/ QUOTE ] I might be missing something about what you're possibly missing , but 2.5 bar = 36psi so it's not that far off what's being quoted, is it? [/ QUOTE ] Well my pump runs on bar so just wanted to double check having confidenly given you the above info ! Link to comment Share on other sites More sharing options...
Rachel Posted July 30, 2006 Report Share Posted July 30, 2006 It's interesting that you guys only need 88Y rated rubber. We must use 92Y rubber here (on the placard!) - but I haven't been able to get a straight answer out of VW Oz as to why... I run 40-42psi front and 38-40psi rear depending on load. It keeps the tyre walls nice and stiff - which you really need on some of the roads around here to avoid sidewall pinching or tearing. [fyi - the Boxster tyres are rated 96Y! ] Link to comment Share on other sites More sharing options...
khutula Posted July 30, 2006 Report Share Posted July 30, 2006 Mine are 92Y Link to comment Share on other sites More sharing options...
