whoopee Posted July 30, 2006 Report Share Posted July 30, 2006 hi, just logged the ecu on my 02 225 s3 and found that the max boost pressure was 2.2 bar and should be 2.5 bar. had a quick look for any holes in tubes, as i read this somewhere a while back but couldnt see any holes. ive recently fitted a new bosch recurculating valve so shouldnt be that? any ideas as to where boost leak could be coming from. anyway is it worth worrying about a leak of 0.3 bar?! do the silicone hoses you can buy for the turbo give any improvement? i also got the air flow logged and max air flow was 189.7 g/s, think this is normal? is it? any help will be grately appreciated. thanks simon. Link to comment Share on other sites More sharing options...
Paul Posted August 10, 2006 Report Share Posted August 10, 2006 vag-com boost logs includes atmospehric pressure. As anything like 2.2 or 2.5 bar MUST be including atmospheric pressure. atmospheric pressure is usually deducted, typically 1013 mbar For ease mose people just deduct 1000mbar or 1 bar. that leaves you with quite a normal chipped boost range of 1.3 - 1.5 bar. figures do fluctuate with ambient temps and pressures, and peak boost is only held momentarily through the revs and then drops off. you could have a leak, just check over all the hoes, including the little ones under the engine cover. Samco's (silicon hoses) help avoid the turbo intake pipe collapse and look nice in the engine bay, they may aid airflow, because they are a constant size and have smooth internals unlike OEM, but its not likely to give you a performance boost. MAF log seems about rigt, up in the 190+ grms sec area, again this will fluctuate due to ambient condiditons, cold and frosty day you may hit 200g/sec all day long. Link to comment Share on other sites More sharing options...
whoopee Posted August 10, 2006 Author Report Share Posted August 10, 2006 thanks paul! great advice as usual. Link to comment Share on other sites More sharing options...
PocketRocket Posted August 10, 2006 Report Share Posted August 10, 2006 Talking about that, for the A3 1.8T owners: whats the max boost pressure you get? Link to comment Share on other sites More sharing options...
