dhali Posted July 31, 2006 Report Share Posted July 31, 2006 hi all, have started to notice a significant loss in power over the last month or so with my car. It has been plugged in for fault codes but nothing was thrown up. Basicly when you put your foot down it accelerates very slowly and there is a buzzing sound when you switch the engine off. this noise appears to come from a black box on the drivers side which has several rubber pipes coming out of it. Car has covered approx 45000 miles on 02 plate. would be grateful for any suggestions. Link to comment Share on other sites More sharing options...
hobbie Posted August 11, 2006 Report Share Posted August 11, 2006 MAF sensor by the sounds of it, very common £75-£100, 10 min job to change Link to comment Share on other sites More sharing options...
dhali Posted August 17, 2006 Author Report Share Posted August 17, 2006 thnks Link to comment Share on other sites More sharing options...
shao_khan Posted August 18, 2006 Report Share Posted August 18, 2006 If you read through the VW forums here it will tell you how to diagnose if it is MAF or not. Basically I think you just need to disconnect it and drive the car - if the performance is the same it must be broke (THink thats the way it works) but read probably a post froM Rustynuts or Mulkbear or Tobes. Link to comment Share on other sites More sharing options...
charlie789 Posted August 23, 2006 Report Share Posted August 23, 2006 performance will be better when disconnected, simply lift out......lm sure that is the case Link to comment Share on other sites More sharing options...
