s3ollie Posted August 9, 2006 Report Share Posted August 9, 2006 hi im getting a DTC 65535 air bag control module memory error - intermitent. does anyone know if this means i have to replace the module? Link to comment Share on other sites More sharing options...
Paul Posted August 9, 2006 Report Share Posted August 9, 2006 Have you cleared it to see if it comes back? Link to comment Share on other sites More sharing options...
s3ollie Posted August 9, 2006 Author Report Share Posted August 9, 2006 Hi yeah ive cleared it and it come straight back. i also have the code 00589 passenger airbag ignighter (n131) resistance to high intermitent. do you think if i fix this one first the other (65535) it will clear? Link to comment Share on other sites More sharing options...
Paul Posted August 9, 2006 Report Share Posted August 9, 2006 Id like to thinks so, But tbh, i would be guessing. Hope you get it sorted. Link to comment Share on other sites More sharing options...
Sebastian Posted August 9, 2006 Report Share Posted August 9, 2006 The airbag control modules back in those days were pretty weird and according to what we've seen over the last years it's a good idea to get the other stuff sorted before actually taking care of the 65535. OTOH you may experience that this code will stay even after you fixed the other one, then you need a new module. Sadly you havn't posted an Auto-Scan or similar which includes the control module part number and other related details, so it's hard to tell you real details. FWIW, if it comes to the point where you need to replace the module, make sure that you get a NEW module from a dealer - do not try to fix it with used or refurbished modules. Link to comment Share on other sites More sharing options...
s3ollie Posted August 10, 2006 Author Report Share Posted August 10, 2006 thanks ill try and post an auto scan but i dont think i can do it as it stop half way through and say i need to register vagcom. ill give it a go Ps do you know where the module is? is it in front of the gear stick in the center console? I have checked the wiring at the air bag end and it all seems fine so i think it maybe the conection the other end??? thanks Link to comment Share on other sites More sharing options...
Sebastian Posted August 10, 2006 Report Share Posted August 10, 2006 [ QUOTE ] thanks ill try and post an auto scan but i dont think i can do it as it stop half way through and say i need to register vagcom. ill give it a go [/ QUOTE ] Alternately, use the Copy Codes button on the fault codes screen "in" the airbag control module. [ QUOTE ] Ps do you know where the module is? is it in front of the gear stick in the center console? [/ QUOTE ] Yep. Link to comment Share on other sites More sharing options...
s3ollie Posted August 22, 2006 Author Report Share Posted August 22, 2006 hi ive got the scan info now was just waiting for a new battery for the laptop. VAG-COM Version: Release 311.2-N Control Module Part Number: 8L0 959 655 G Component and/or Version: Airbag Front+Seite 1007 Software Coding: 01104 Work Shop Code: WSC 06313 2 Faults Found: 65535 - Internal Control Module Memory Error 00-10 - - - Intermittent 00589 - Shareware Version. To Decode all DTCs 32-10 - Please Register/Activate - Intermittent The 00589 is the passenger airbag ignighter Link to comment Share on other sites More sharing options...
Sebastian Posted August 24, 2006 Report Share Posted August 24, 2006 One of the "famous" Airbag Generation 8 modules. We've seen issues like that in the past and there is usually only one way to get rid of that - buy a new control module. At least according to what we have seen, it seems that these faults are caused by under voltage at cold starts and/or by starting the car up after a dead battery. As mentioned by others before, fix the normal airbag fault and try to clear codes but I doubt you'll get rid of the 65535. If you need to replace the control module get a new one, Audi has replaced the 8L0-959-655-G with an 8L0-959-655-L, which has updated hardware and software. Link to comment Share on other sites More sharing options...
s3ollie Posted August 24, 2006 Author Report Share Posted August 24, 2006 thanks for the info sebastian. Does anyone know what sort of price im looking at for a new module? is it as easy as just fitting the new one or it or will it need coding ect....? Link to comment Share on other sites More sharing options...
Sebastian Posted August 24, 2006 Report Share Posted August 24, 2006 The good news is, the price for these came way down a couple of month ago, so it's now somewhere around 300 EUR (excl. VAT). After fitting it does require coding, but that should not be a problem - just take the coding of the old module. Link to comment Share on other sites More sharing options...
s3ollie Posted September 3, 2006 Author Report Share Posted September 3, 2006 i have found this module on ebay for a audi A3 http://cgi.ebay.co.uk/Audi-A3-1997-2003-...1QQcmdZViewItem it has the letter J after the the number, would this be ok for a replacement or will i have to get the L one. the faulty one i have is a G Link to comment Share on other sites More sharing options...
Sebastian Posted September 3, 2006 Report Share Posted September 3, 2006 The 8L0-959-655-J would be compatible, but it has been replaced the 8L0-959-655-L too so I would not suggest to get the 8L0-959-655-J. The new L module is 200 GPB vs the used one for 160 GPB, IMHO not worth it - especially since I would never trust a used module. Link to comment Share on other sites More sharing options...
s3ollie Posted September 3, 2006 Author Report Share Posted September 3, 2006 ok thanks for that. i phonned audi uk and i think they said it will be £270 ish + vat @ 17.5%. do you know anywhere in the uk that supply these. thanks again Link to comment Share on other sites More sharing options...
Paul Posted September 3, 2006 Report Share Posted September 3, 2006 If your not aware, Sebastian is based in the US. Id not want to trust a second hand airbag controller either. Try sending www.vagparts.com an email with the part number and as much info about your car model/year etc as possible. Link to comment Share on other sites More sharing options...
Sebastian Posted September 3, 2006 Report Share Posted September 3, 2006 [ QUOTE ] If your not aware, Sebastian is based in the US. [/ QUOTE ] Actually I'm not. Magdeburg, Germany Anyway, the prices I mentioned were the German ones, so it's a bit strange why they are that much higher in the UK. Link to comment Share on other sites More sharing options...
Paul Posted September 4, 2006 Report Share Posted September 4, 2006 I stand corrected. Link to comment Share on other sites More sharing options...
s3ollie Posted September 4, 2006 Author Report Share Posted September 4, 2006 [ QUOTE ] If your not aware, Sebastian is based in the US. Id not want to trust a second hand airbag controller either. Try sending www.vagparts.com an email with the part number and as much info about your car model/year etc as possible. [/ QUOTE ] Thanks ill try that Link to comment Share on other sites More sharing options...
s3ollie Posted September 4, 2006 Author Report Share Posted September 4, 2006 [ QUOTE ] Anyway, the prices I mentioned were the German ones, so it's a bit strange why they are that much higher in the UK. [/ QUOTE ] We get ripped off for most things in the uk!! Link to comment Share on other sites More sharing options...
s3ollie Posted October 16, 2006 Author Report Share Posted October 16, 2006 I have ordered a new module from vagparts.com and it is going to arrive in a few days. Now i need some information on changing the unit, does anyone know of any web pages or posts anywhere or have any advice to do with removing the center console, removing the unit and then coding ect.... in know i have to disconnect the - battery terminal first Link to comment Share on other sites More sharing options...
TDiAvant Posted October 16, 2006 Report Share Posted October 16, 2006 What year, is your car s3ollie? I should be able to get you some information on fitting etc, but not the coding Link to comment Share on other sites More sharing options...
s3ollie Posted October 16, 2006 Author Report Share Posted October 16, 2006 Hi thanks very much the car is a V reg 1999 Link to comment Share on other sites More sharing options...
TDiAvant Posted October 16, 2006 Report Share Posted October 16, 2006 email sent Link to comment Share on other sites More sharing options...
s3ollie Posted October 16, 2006 Author Report Share Posted October 16, 2006 Link to comment Share on other sites More sharing options...
Guard Posted November 10, 2006 Report Share Posted November 10, 2006 Hi, i have the same (i think) problem. Here is the info from VAG (it's from VW Passat): Address 01 ------------------------------------------------------- Controller: 028 906 021 DD Component: 1.9l R4 EDC SG D84 Coding: 00000 Shop #: WSC 00000 1 Faults Found: 01117 - Generator Terminal DF Load Signal 27-00 - Implausible Signal Readiness: N/A Address 03 ------------------------------------------------------- Controller: 3A0 907 379 Component: ABS ITTAE 20 GI V00 Coding: 04505 Shop #: WSC 00000 7 Faults Found: 00283 - Front Left ABS Wheel Speed Sensor (G47) 35-00 - - 00287 - ABS Wheel Speed Sensor: Rear Right (G44) 35-00 - - 01276 - ABS Hydraulic Pump (V64) 16-10 - Signal Outside Specifications - Intermittent 00290 - ABS Wheel Speed Sensor: Rear Left (G46) 16-10 - Signal Outside Specifications - Intermittent 00290 - ABS Wheel Speed Sensor: Rear Left (G46) 04-10 - Mechanical Malfunction - Intermittent 00668 - Supply Voltage Terminal 30 16-10 - Signal Outside Specifications - Intermittent 01130 - ABS Operation 27-10 - Implausible Signal - Intermittent Address 15 ------------------------------------------------------- Controller: 6N0 909 603 H Component: AIRBAG VW2 V00 Coding: 00072 Shop #: WSC 05311 2 Faults Found: 00532 - Supply Voltage B+ 06-10 - Signal to High - Intermittent 65535 - Internal Control Module Memory Error 00-00 - - The problem starts when my alternator died ... It has been repaired and from that time i can't clear any of that codes above (ABS is not working from begining, no time to replace sensors ). Could my Airbag module died ? And what the other codes mean ? Thanks for any help. Link to comment Share on other sites More sharing options...
