Andy_Bangle Posted October 11, 2006 Report Share Posted October 11, 2006 anyone know exactly where the engine number is located on the 2006 3.0 V6 TDI engine? or can it gleemed from the VIN? Link to comment Share on other sites More sharing options...
stig414 Posted October 11, 2006 Report Share Posted October 11, 2006 Engine number The engine number (“engine code” and “serial number”) can be found at the front below the toothed belt for the high-pressure pump (left-side) -arrow-. There is also a sticker on the intake manifold showing the “engine code” and “serial number”. The engine code is also included on the vehicle data sticker. NoteOn some versions the engine number is concealed by an idler roller for the poly-V belt. Removing idler roller for poly V-belt. Does that help? Link to comment Share on other sites More sharing options...
Andy_Bangle Posted October 11, 2006 Author Report Share Posted October 11, 2006 Jeez they don't make it easy to find. Link to comment Share on other sites More sharing options...
Tobes49 Posted October 11, 2006 Report Share Posted October 11, 2006 In the front of the service book, On a white sticker in the boot around the spare wheel, will tell you the engine code. If you need the number you will have to look on the engine. Link to comment Share on other sites More sharing options...
Andy_Bangle Posted October 12, 2006 Author Report Share Posted October 12, 2006 [ QUOTE ] If you need the number you will have to look on the engine. [/ QUOTE ] Gotta see the 3.0TDI engine to belive it, even with the plastic cover off you don't see a lot of engine block. Link to comment Share on other sites More sharing options...
