3.0 V6 TDI - Engine number location?
Andy_Bangle
Engine number
The engine number (“engine code” and “serial number”) can be found at the front below the toothed belt for the high-pressure pump (left-side) -arrow-.
There is also a sticker on the intake manifold showing the “engine code” and “serial number”.
The engine code is also included on the vehicle data sticker.
NoteOn some versions the engine number is concealed by an idler roller for the poly-V belt. Removing idler roller for poly V-belt.
Does that help?
