Cars Detailed / Valeted by Cambridge Autogleam.
jediknight83
yes that is a regular comment... that it looks better than when it was new. ALot of dealers dont put much emphasis on how well the paint shines.. and neither do alot of owners... to some.. as long as it is clean (as in free of dirt) then they are happy. My services are available to those who want more than just a clean car.
  • Replies 341
  • Created
  • Last Reply
Top Posters In This Topic
Wonder if I might ask for a touch of advice from the master. As mentioned the Gti is showing a few VW scars. Namely very light scratching here and there as a result of washing and/or lifeshine'ing poorly.
What do you recommend to shift these? She is dark metallic blue. Would a regular polish be the best bet?
i actually really rate autoglym super resim polish. It wont do much to remove them completely but does a great job of cleaning up the paint and filling or hiding them and under a good wax the results can last a good few months
to truely fix the scratches i would recommend machine polishing from a professional followed by a good wax.
Hi Nathan
Your work is top quality as ever!! The interior of that car looks awful. The steering wheel, the pedals, the gear stick!! What did you think on your little low-speed test drive??
Thanks
Geoff
the interior is a thing of beauty. its all carbon fibre inside.. the steering wheel has been changed from the leather one as its used alot on the track. The gear stick falls just in the right place aswell.
Car number 3 for this customer and a different venue for today. The GT3 is his dedicated track car and spends alot of its time at Fearnsport Porsche Specialists at Silverstone. Firstly id like to say thanks to them for being very accommodating. Im pretty sure im going to be back there now and again for other cars aswell which will be nice as they have some amazing machinery there!
Anyway.. left the house at 7am and arrived at Fearnsport at 8:45 after passing 2 accidents on the A14 that had happened no more than 10 cars ahead of me!
Wheeled the GT3 outside and took a couple of before shots. Not terrible swirls but swirls none the less.
Pre-washed with AG PM3 via the foam lance. Then shampoo'd with AG shampoo and dried with a sonus yellow drying towel. Tar / Rubber marks removed with AG tar remover and then the whole car was clayed with sonus green clay.
Then although it was still chilly it was nice and sunny so i thought i'd detail outside for a while. Did a few tests and decided onces again that ip 3.01 on a megs yellow polishing pad was the way forwards. Most of the front was covered in armorfend stuff (being a track car) but the rest was all treated in the same way
Then it actually started snowing so it was into the garage for the premium paint cleanse applied via machine on a megs finishing pad at 600rpm
Then on with the 47% carnauba wax applied by hand.. much to the amusment of the staff at fearnsport who made many jokes about me massaging a car.
This is the only pic of me 'massaging' in which i didnt look like a dork (some will argue.. i still do!
Andy ... Fearnsports owner watching over me
Thankfully after almost 11 hrs the staff were all commenting on how good it looked and how impressed with the amount of work i had put in.
I was pretty knackered so didnt take many after pics and completely forgot to take after correction shots... sorry
Thanks for looking...
Nathan
As I am told - thats the difference between a clean car and a shiny one!
This is similar to how mine looked after the collinite 915 app - "glowed" and almost looked metallic! This is certainly glowing though - again looks metallic (or at least pearl coated).
Firstly a little history of this car. Its a 1995 Virage Volante with the 6.3 widebody cosmetic look. However toward the end of the production Aston ran out of the normal 5.3 engine that should be fitted to this car. So the last 11 Virage Volante's got the new engine meant for the Vantage Coupe (to be released in 96) which had an extra 40bhp... this was the 6th from last
Right... enough of that... This was booked in for a 2 day detail and was supposed to be at the customers house but with the poor weather forecast it was relocated to the owners business where there was a roomy warehouse.
Once pre-washed and shampoo'd this is what it looked like.... I had been warned it was in bad condition..
th_AstonMartinVirage1.jpg th_AstonMartinVirage2.jpg th_AstonMartinVirage3.jpg th_AstonMartinVirage4.jpg
Then clayed the whole car... which i then realised just how big it is!
The PTG showed quite a mix! 340 one side of the bonnet and 150 the other side. 100 on the doors. 250 on the front wings and 400 on the boot lid. With that in mind i tested on a number of panels to find the best method. On the bonet i used a mix of ip3.01 with a yellow megs pad up to ip3.01 with a drop of power gloss on a burgandy pad. most of the rest of the car was ip3.01 on a yellow pad with a drop of PG here and there.
The paint came up really well apart from a few rather deep marks on the bonnet and the boot lid (these were hit 2 or 3 times with mimimal paint depth change and agreed with owner these can be tackled next time with some wet and dry... but neither of our schedules would allow it at the moment)
During correction with the brand new hood well protected.
My attempt at a couple of 50:50 shots.. sorry there not that great.. will work on these in the future
After on the bonnet
Anyway this took hours... so i had to then crack on with the premium paint cleanse and then the premium 47% carnauba wax... i had to get the 1st coat on by the end of day 1 so it could cure over night ready for the 2nd coat on day 2.
During and after waxing..
Finished the day at 6:30pm
DAY 2 ... 10am (after collecting my s3 from the garage so was running late)
Started very much the same way DAY 1 ended... smile.gif .... after a wipe down with some last touch..
2nd coat applied ... Next up were the wheels and exhaust. The owner had said not to worry too much as there were due to be stripped down and refurbed soon... but for my piece of mind (and because i didnt want them dirty in my photos smile.gif ) i had a go anyway. Autosol metal polish with a foam pad did quite a good job (but obviously still need doing profesionally) Then they were done with SRP and waxed with collinite 915.
Before
After
Exhaust was done the same
Time was really cracking on so next was the glass in and out with AG glass cream polish, Arches and tyres dressed with AG products, paint wiped down with Optimum Car Wax, Interior wiped down and leather fed with Gliptone Liquid Leather.... and breathe.... and photograph smile.gif
th_AstonMartinVirage19.jpg th_AstonMartinVirage21.jpg th_AstonMartinVirage22.jpg th_AstonMartinVirage23.jpg th_AstonMartinVirage28.jpg
Owner was over the moon.
Thanks for looking
Nathan
Im staying down in a place called Forrest Row (nr Tunbridge Wells) this week as i have a client that wants 3 of his cars given a deswirl detail.
So yesterday morning i turned up at 8:30 and wheeled this out of the garage.
Covered in dirt and dust it was quite difficult to see the defects. AG PM3 TFR and pressure rinsed, Shampoo'd, Wheels cleaned in and out, Then clayed with Sonus Green and into the garage and under the lights and time to sit down for 5 mins...
So knowing Aston paint to be quite soft i started trying 85rd... which took 50% out... so i tried 106ff.. which did 80-90% so i tried adding a drop of ip3.01 in with 106ff... which did the job... but left maring... so then i had to finish with 85rd on a finishing pad.. so the job took twice as long.. 7hrs + on machine polishing alone.
anyway... before and 50:50 shot.
Then after a back breaking day i applied the premium paint cleanse by hand and then the 47% Carnauba wax. Got 1st coat all finished by 8:30pm and then home for a well earned nap.
DAY 2
Started with a rinse and a wipe down.. got these pics of the water beading on the 1st coat of wax
then on with the 2nd coat
Time was ticking and i needed to start the second car asap (you will see it in the background of some of the pics.. full write up tomorrow night). Cleaned the glass with AG glass polish, dressed arches and tyres, Cleaned the interior and fed the leather with gliptone liquid leather. Waxed the wheels with collinite 915 and then took some photos... sorry there are loads .. actually... im not sorry.. i enjoy the photography part as much as other aspects of the detail... anyway....
th_DavidsAstonVanquish12.jpg th_DavidsAstonVanquish13.jpg th_DavidsAstonVanquish15.jpg th_DavidsAstonVanquish16.jpg th_DavidsAstonVanquish26.jpg
Thanks...
Nathan
