seansimpson Posted December 29, 2006 Report Share Posted December 29, 2006 Has anyone been able to program the Central Convenience Controller (Address 46) to roll up the windows using the remote keyfob when locking the car. I've checked the coding (original value 06895) which would suggest Bit 6 (comfort controls) is switched on and the original value for adaptation channel 62 is set to 95 which would suggest Bit 0 (windows up with remote) is also on. There are no fault codes reported. Am I missing something obvious Link to comment Share on other sites More sharing options...
Paul Posted December 29, 2006 Report Share Posted December 29, 2006 Petrol Dave might be able to shed some light on this. I know he owns an RS4 (B7) and is handy with vag-com. Im not familiar with the different coding on the newer models. i've not had the opportunity to dabble. Link to comment Share on other sites More sharing options...
PetrolDave Posted December 29, 2006 Report Share Posted December 29, 2006 My RS4 come coded with this working from delivery. Check the details on the Ross Tech website for the B6 (the same applies to the B7). Link to comment Share on other sites More sharing options...
shark_90 Posted December 30, 2006 Report Share Posted December 30, 2006 I managed to screw this up on my B6 once. Basically turning the function off and back on again kicked it into life. Could be worth a try if it's still not working. Forgive me for asking the obvious, but you are holding the button down for long enough aren't you? Link to comment Share on other sites More sharing options...
seansimpson Posted December 30, 2006 Author Report Share Posted December 30, 2006 Mmmmm yep that would be THE obvious thing to try. Link to comment Share on other sites More sharing options...
shark_90 Posted December 31, 2006 Report Share Posted December 31, 2006 Well, did it work? Link to comment Share on other sites More sharing options...
Sebastian Posted December 31, 2006 Report Share Posted December 31, 2006 You need to check/alter both, coding and adaptation channel 062. http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Comfort_System Link to comment Share on other sites More sharing options...
seansimpson Posted December 31, 2006 Author Report Share Posted December 31, 2006 Yep it works all right. No changes to coding or adaptation required. Must remember to RTFM beforehand. Link to comment Share on other sites More sharing options...
Sebastian Posted December 31, 2006 Report Share Posted December 31, 2006 [ QUOTE ] No changes to coding or adaptation required. [/ QUOTE ] Sorry, forgot this is a UK forum! The US models need the coding/adaptation since it's disabled by factory. Link to comment Share on other sites More sharing options...
shark_90 Posted December 31, 2006 Report Share Posted December 31, 2006 [ QUOTE ] Yep it works all right. No changes to coding or adaptation required. Must remember to RTFM beforehand. [/ QUOTE ] Excellent Link to comment Share on other sites More sharing options...
