carnell Posted December 30, 2006 Report Share Posted December 30, 2006 Has anybody had any problems with engine cooling fan coming on, even when engine is cold for instance first stared this morn and 30seconds later fan kicks in and goes off after a couple of mins, been out today done about 50 mile running around,must of come on half a dozen times. Been back to stealers twice no fault found, this has been happening for a couple of months now.Time for another trip to dealers. Link to comment Share on other sites More sharing options...
fresco1 Posted December 30, 2006 Report Share Posted December 30, 2006 I know the cooling fan can run after you've been out and killed off the engine, but would have assumed the fan running when the engine is cold is not too clever. Faulty sensor perhaps? Link to comment Share on other sites More sharing options...
carnell Posted December 30, 2006 Author Report Share Posted December 30, 2006 Stealers couldn"t find anything wrong, same old story dosnt kick in while its been at stealers, should i take it in and see if they will change the sensor and see if it stops it,starting to get on my nerves now Link to comment Share on other sites More sharing options...
SMB Posted December 30, 2006 Report Share Posted December 30, 2006 did you have the air con on ( climate on without econ pressed?) if so the fan runninging is a required part of the air con running. The condenseer will run to dehumidify the air even if you have set a higher temperature Link to comment Share on other sites More sharing options...
carnell Posted December 30, 2006 Author Report Share Posted December 30, 2006 i dont know but i will try it tomorrow, thanks Link to comment Share on other sites More sharing options...
carnell Posted December 31, 2006 Author Report Share Posted December 31, 2006 fan is on when aircon is on, but it is the smaller more powerful one next to it that keeps kicking in, the one to cool the engine. Link to comment Share on other sites More sharing options...
fresco1 Posted December 31, 2006 Report Share Posted December 31, 2006 Hmmmm. Sounds like it has a fault. Assuming your coolant levels etc are okay, there should be a limited number of occasions / conditions under which the main fan would run. Some monitored condition has to be met for the ECU to activate the cooling fan, and if you are getting spurious activations then something is remiss. I would imagine your best bet is to have a discussion with the stealer, and perhaps get them to do a road-test with you under the conditions you believe are most likely to recreate the fault. Alternatively, they may need to hang on to the car overnight and drive it to locate the fault (I got my stealer to do this recently, and all faults replicated themselves and were finally fixed). Bottom line, it does sound like a fault. Link to comment Share on other sites More sharing options...
carnell Posted December 31, 2006 Author Report Share Posted December 31, 2006 thanks for that dosn"t even have to be driven, can come on on start up sometimes,then will not do it for a week or more sometimes a dozen times a day for a few seconds at a time. Link to comment Share on other sites More sharing options...
AidanR Posted January 1, 2007 Report Share Posted January 1, 2007 I had the same problem, the fan comes on even though the engine is stone cold.( Everyone around you thinks you've been driving at warp 9 its so loud! ) The dealer said the cooling fan had to be changed... Which they did and I haven't had any problems since. Hope this helps Link to comment Share on other sites More sharing options...
newblackGTi Posted January 1, 2007 Report Share Posted January 1, 2007 Neil I had the same problem a few months back, stealers fitted a new air con/cooling system in and all sorted under warranty... just the other problems to sort now! Drivers door seal hanging off Rear wiper with mind of its own Bonnet won't open now, no matter how far round you tug the release (particular pain now I'm out of washer fluid) Rusting hub caps Corroding exhaust tips Slight rusting around the door tops..! Great these cars aren't they! Link to comment Share on other sites More sharing options...
SMB Posted January 1, 2007 Report Share Posted January 1, 2007 rust!!!! where on the door tops? Link to comment Share on other sites More sharing options...
newblackGTi Posted January 1, 2007 Report Share Posted January 1, 2007 the thin strip that separates the 2 bits of glass on the rear doors is going slightly rusty at the top... Should be easily replaced but you just dont expect that on this type of car!! Link to comment Share on other sites More sharing options...
AidanR Posted January 1, 2007 Report Share Posted January 1, 2007 My rear wiper seems to have a mind of its own too- it mainly comes on by itself when you first start the engine regardless of where the wiper stalk is ... I hadn't thought it could taken in under warranty. Thanks for the idea : Link to comment Share on other sites More sharing options...
carnell Posted January 1, 2007 Author Report Share Posted January 1, 2007 Aiden thanks for your reply, sounds like you have a lot more probs than me, i will talk to stealers tomorrow,thanks again hope u get yours sorted,only other problem i had was a front fog lights misting up which was replaced under warranty. Link to comment Share on other sites More sharing options...
AlanH Posted January 1, 2007 Report Share Posted January 1, 2007 [ QUOTE ] My rear wiper seems to have a mind of its own too- it mainly comes on by itself when you first start the engine regardless of where the wiper stalk is ... I hadn't thought it could taken in under warranty. Thanks for the idea : [/ QUOTE ] This was a fairly common problem a while ago - solution is replacement of the rear wiper motor under warranty. Had mine replaced after about 6 months. Link to comment Share on other sites More sharing options...
AidanR Posted January 1, 2007 Report Share Posted January 1, 2007 Not had many probs really- Just the steering rack creaking, which needed replacing. The cooling fan thing and this rear wiper problem. No problems with rust or bodywork though, hope you get it sorted out. Keep us updated Neil, just reading previous post and realised its not your car thats rusty its new black gti's! A few too many stellas doesn't help my reading hope you get it sorted too!! Link to comment Share on other sites More sharing options...
benjie Posted January 1, 2007 Report Share Posted January 1, 2007 Have a look here as you may have this - http://uk-mkivs.net/forums/thread/449470.aspx Link to comment Share on other sites More sharing options...
carnell Posted January 1, 2007 Author Report Share Posted January 1, 2007 Aiden it was me replying to you on reading new black gtis post my mistake,far 2 many last night,vodka redbulls and magners not in the same glass might i add last night HAPPY NEW YEAR Benji had a look at that site but don"t think it is that because 1st fan is working ok to cool compressor but engine fan comes on when it feels like it,thanks anyway.off to dealers 2moro Link to comment Share on other sites More sharing options...
SMB Posted January 2, 2007 Report Share Posted January 2, 2007 [ QUOTE ] the thin strip that separates the 2 bits of glass on the rear doors is going slightly rusty at the top... Should be easily replaced but you just dont expect that on this type of car!! [/ QUOTE ] ah glad to say I don't have that problem as it's not there on a 3 door. Link to comment Share on other sites More sharing options...
Snoopy Posted January 3, 2007 Report Share Posted January 3, 2007 [ QUOTE ] the thin strip that separates the 2 bits of glass on the rear doors is going slightly rusty at the top... Should be easily replaced but you just dont expect that on this type of car!! [/ QUOTE ] Sen this on loads of other cars in the past, Alfas use to suffer it bad. Should not have happened this early though! Link to comment Share on other sites More sharing options...
