Flash Car Wash
ahaydock
I have used the search function but cannot find any reference to the Flash Car Wash. I have one of these and do use it every so often and find it does a good job. OK so it is not like a proper wash and polish but then it doesn't claim to be and it only takes me 20 minutes, which is ideal for those times it needs a quick clean but I havn't got time to do the works.
What are peoples thought on these?
i used one for some time. I didnt use the shampoo function, basically i used it to rinse the car off at the end and then used the water filter which was great. In the summer when its hot, i always struggle to get cars dry before they are covered in water marks, using the filter solved this and allowed me to wipe the car dry to a nice finish.
i just prefer to use Meguiars, nice quality, tried and tested! Read a few posts which suggests the flash systems ingredients are very close to washing up liquid
This is one reason why I don't use the shampoo. They say the gun should only be used with their unique shampoo and that the Auto-Dry works better in conjunction with their shampoo, but they would, wouldn't they. ROLLEY~14.GIF
I did use it a couple of times on my last car and the results were acceptable. However, I haven't used it on the Audi. I'd rather use a shampoo from an automotive company, not from a company that produces kitchen cleaners! smirk.gif
[/ QUOTE ]Yeah I read that, do you find it works OK not using their shampoo? I did use my Zymol once intead of theirs but found it didn't dry properly but I cannot be sure the filter didn't need replacing.
I used it for a while and found it quite good. I'm ashamed to say it, but I was 'scared off' by all the comments from 'serious detailers' that it was like washing up liquid and would strip wax etc., so in the end I went back to my Megs!
I'm not sure how much was real factual info and how much was just assumption. After all, they are a huge company - how difficult can it be to produce a decent shampoo?
I agree and am concerned it may strip the wax. That is why I am interested to konw whether you can get t he same reulst using another shampoo like megs and just use the autodry filter?
I guess once the Flash shampoo has run out you could actually fill up the Flash Gun with whatever shampoo you normally use - sponge and ryan_w is this what you did?
I did try putting my NXT wash into the Flash Gun, but I went back to the normal bucket method. It was a long time ago and the memory is a bit hazy, but I recall it not really impressing me. It might have been something to do with the amount of detergent it was using - lots.
I just preferred the 'normal' method, so I started to use the Flash Auto-Dry on its own, in the Summer, when I couldn't dry the car quickly enough with my 'Water Magnet' to prevent drying marks. (Like others have mentioned above.)
On a similar note, I'm tempted by foam guns like this one. But they seem a little expensive to me. Especially as I fear it will still require the use of a washmitt and elbow grease, which sort of defeats the purpose of the foam gun in the first place. crazy.gif
