Recoding AudioPilot for Bose after RNS-E install.
terrymcg
Hi,
I have recently added an RNS-E unit to my A3. I have the Bose Sound System. I take it that the unit I bought was not from a Bose car as it still has Gala settings enabled in the menu, and as I understand you should not be using Gala if you have Bose. So:
1. Will my car need any other recoding done to make the Bose work properly or is it just the AudioPilot that needs enabled.
2. I know nothing about Vag-com or what cables to buy from ebay, so could someone give me a quick idiots guide in what cable I need and software to download.
3. Is there anyone near West Lothian that knows what they are doing and has the stuff that may be able to help me out.
Cheers,
Terry
Since you have a completely CAN-based car, you're not going to find what you need on fleaBay. The most cost-effective setup for your car is the Micro-CAN interface:
http://www.ross-tech.com/vag-com/Micro-CAN.html
We've got the codings for the RNS-E pretty well documented here:
http://wiki.ross-tech.com/index.php/Audi_Radio/Navigation_System_%28RNS-E%29#Coding
-Uwe-
