Leppy Posted March 1, 2007 Report Share Posted March 1, 2007 Hi All, I need some help, I have a manual on cd for my bike - CBR600F - 2002 But it doesn't give info on how to use the digital display buttons. I know there is only 2 buttons, but can anyone tell me what functions can be used and how? I know KPH/MPH can be toggled as well as resetting distance, clock etc, but in what order do you hold down the buttons?? See atatched for what buttons I mean. Thanks Link to comment Share on other sites More sharing options...
chipandpin Posted March 2, 2007 Report Share Posted March 2, 2007 Top button = select Bottom button = Reset Speed and Mileage unit change - push and hold the select button DIgital clock - to adjust the time, press and hold both buttons for 2 seconds. To set the hour, press the reset button. Press select , then use the reset button to set the minutes. To end press the select button Tripmeter - switch between a and b using the select button. To reset push and hold the reset button. Hope that helps Link to comment Share on other sites More sharing options...
