dogbucket Posted July 10, 2007 Report Share Posted July 10, 2007 I have (had) the same problem re. the power socket. Its seems the plug is abit of a loose fit in the socket. Bending the centre pin on the socket slightly did the trick. Link to comment Share on other sites More sharing options...
RedRobin Posted July 10, 2007 Author Report Share Posted July 10, 2007 ....Ah....Do you mean bending the centre pin which is within the socket of the 'Power Bracket' [using the terms used in the Manual], so that the male jack connector has a tighter fit? [said the actress to the bishop ] I'll try that. Link to comment Share on other sites More sharing options...
dogbucket Posted July 10, 2007 Report Share Posted July 10, 2007 yup thats right. Before I did that I had the whole thing apart and there was nothing wrong inside. Link to comment Share on other sites More sharing options...
RedRobin Posted July 10, 2007 Author Report Share Posted July 10, 2007 I'll post here if it works for me too and then I'll inform Origin of the workaround. Link to comment Share on other sites More sharing options...
RedRobin Posted July 20, 2007 Author Report Share Posted July 20, 2007 ....Well it hasn't worked for me. It's most definitely the poorer road surfaces which create the connectivity problem. Problems on parts of M25 and M20, and then no problems throughout the whole of France except on going fast over a couple of bridge expansion joints, and then 1,700 miles later the dear old UK M20/M25 problems again . Reaching out and pushing the main unit back against its power base connections re-establishes connectivity but it's not good. The other point I found disappointing was the amount of distance it takes to recalibrate itself to either mph or kmh - Not very comforting to be back on the M25 with a reading of 130 !! On the plus side, the large speed display is invaluable and couldn't be better for keeping you speed-aware, and with GPS accuracy - It's just like having a proper heads-up display . Link to comment Share on other sites More sharing options...
PetrolDave Posted July 21, 2007 Report Share Posted July 21, 2007 [ QUOTE ] The other point I found disappointing was the amount of distance it takes to recalibrate itself to either mph or kmh - Not very comforting to be back on the M25 with a reading of 130 !! [/ QUOTE ] I'd didn't have that problem when we came back from France 3 weeks ago. I changed the setting from kmh to mph before switching off the engine once we were on the train in the Chunnel, and as soon as I drove off the train it was showing mph. Thing I really love is the clear display of everything you need to know in average speed zones - limit, current speed and current average. Only thing I don't like is the amount of beeping while you are going through the M25 variable speed limit zone. Link to comment Share on other sites More sharing options...
RedRobin Posted July 21, 2007 Author Report Share Posted July 21, 2007 ....I switched my settings in the Eurotunnel too - With ignition on but engine not running. I'd rather hear all that beeping on the M25 than only visual warnings, but if they are variable and not displaying a limit, how do we know what the max speed is? It wasn't clear to me amongst all the traffic. Link to comment Share on other sites More sharing options...
helfinger Posted July 27, 2007 Report Share Posted July 27, 2007 [ QUOTE ] Reaching out and pushing the main unit back against its power base connections re-establishes connectivity but it's not good. [/ QUOTE ] why don't you just send it back and get it replaced. i have one in my TVR and no issues at all, and im sure mine would be disconnecting all the time if there was a general issue which i don't think there is........ i have sold a large number of the pogo alert units with no connectivity issues at all...sounds as just it a faulty unit.... Link to comment Share on other sites More sharing options...
RedRobin Posted July 27, 2007 Author Report Share Posted July 27, 2007 ....Then I think I might send it back but I'm off on another Europe trip later next week and won't want to be without a unit. I'll phone Origin on Monday and see what can be done - If they'll send me a replacement and then I'll send them mine after I recieve it and before I go abroad. Link to comment Share on other sites More sharing options...
ekin_88 Posted August 20, 2007 Report Share Posted August 20, 2007 [ QUOTE ] ....I switched my settings in the Eurotunnel too - With ignition on but engine not running. I'd rather hear all that beeping on the M25 than only visual warnings, but if they are variable and not displaying a limit, how do we know what the max speed is? It wasn't clear to me amongst all the traffic. [/ QUOTE ] Hi RR, On the Variable stretches off road where their is a speed camera, like the M25, when the over heads displys show eg 50mph max then the camera comes on and is live for snapping if you exceed that speed limit, when you have no speed restrictions then you can travel at 70mph or the limit of the road. Hope this helps Link to comment Share on other sites More sharing options...
RedRobin Posted August 20, 2007 Author Report Share Posted August 20, 2007 .... It helps Link to comment Share on other sites More sharing options...
craigyb Posted August 21, 2007 Report Share Posted August 21, 2007 Origin are offering a trade in on B2's for Pogo Alerts or Pogo Drives. I have just ordered my pogo alert upgrade. Link to comment Share on other sites More sharing options...
RedRobin Posted August 21, 2007 Author Report Share Posted August 21, 2007 Origin have just replaced my 'power base'. I sent my faulty one on Friday afternoon and recieved a new replacement by Special Delivery early this morning . Excellent service . Connectivity problem appears solved so far and also calibration kmh > < mph is now instant. Link to comment Share on other sites More sharing options...
craigyb Posted August 21, 2007 Report Share Posted August 21, 2007 I juts got my Pogo, not impressed. I need an external antenna and one is not supplied like it was with the B2, so now I have to spend another £44 on an antenna cos the B2 antenna has a different connector. I might send the whole thing back. Link to comment Share on other sites More sharing options...
RedRobin Posted August 21, 2007 Author Report Share Posted August 21, 2007 ....I assume you are talking about the Pogo Drive and not the Pogo Alert. I think they'll accept it back with no questions asked if within 14 days of purchase. Link to comment Share on other sites More sharing options...
craigyb Posted August 21, 2007 Report Share Posted August 21, 2007 No, pogo alert Link to comment Share on other sites More sharing options...
RedRobin Posted August 21, 2007 Author Report Share Posted August 21, 2007 [ QUOTE ] No, pogo alert [/ QUOTE ] ....Then I don't understand the need for an antennae Link to comment Share on other sites More sharing options...
craigyb Posted August 21, 2007 Report Share Posted August 21, 2007 Metal impregnated glass in the A8 stops all GPS signals. My B2 0nly works with the external antenna. Link to comment Share on other sites More sharing options...
burble Posted August 23, 2007 Report Share Posted August 23, 2007 I just got an email from the good inward at the office saying that the Pogo Alert I ordered yesterday afternoon is sitting on my desk waiting for me for hwen I get back from France Link to comment Share on other sites More sharing options...
gizze Posted August 24, 2007 Report Share Posted August 24, 2007 Craig, what do you think of the size of the unit?? I am after something that I can install stealthy, and it looks too deep to do anything like that with?? Link to comment Share on other sites More sharing options...
craigyb Posted August 24, 2007 Report Share Posted August 24, 2007 It is quite deep compared to the B2, probably around 3 times deeper Link to comment Share on other sites More sharing options...
jettadeluxe Posted August 25, 2007 Report Share Posted August 25, 2007 [ QUOTE ] Metal impregnated glass in the A8 stops all GPS signals. My B2 0nly works with the external antenna. [/ QUOTE ] Yup, I have to run an external antenna on my A8 for my TomTom. I ran in under the sill trims and B pillar trim, up into the boot and through the boot seal, affixing the antenna block to the base of the rear window. Its discreet enough for me! Link to comment Share on other sites More sharing options...
burble Posted August 25, 2007 Report Share Posted August 25, 2007 I've just been out to try out the Pogo Alert and on first impressions I like it. It took a while to position it so that the sun glare wasn't making it hard to see and it does seem to suffer from glare worse than my Tomtom Go 910. For now I'm just using the windscreen mount but I'll hardwire it into the .:R after she's arrived. All I need now is a carry case - any ideas where I can buy one? Link to comment Share on other sites More sharing options...
Tumbletop Posted August 29, 2007 Report Share Posted August 29, 2007 Thanks to your excellent review RedRobbin, I've just ordered one from Helfinger. You should be on commission! Link to comment Share on other sites More sharing options...
GCab Posted August 29, 2007 Report Share Posted August 29, 2007 I think the MicroRP remains the most stealthy/least nickable of the detectors, am I right Craig? Shame I left mine in the last car when I exchanged - d'oh. Link to comment Share on other sites More sharing options...
