hmetwally Posted June 15, 2007 Report Share Posted June 15, 2007 Hi there, Very nice forum. I am about to buy a coupe TT with the 2.0 turbo. Where I live its impossible to test drive, so i wanted to get some description of the experiance on the ride quality, as in how tough it would be vis a vis road bumps tc.(which are also plenty where i live). I am getting the standard suspension and the choice between 17 and 18 inch wheels. Any input out there? I know it sounds bizzare buying the car without test driving it which goes to show how useful this forum can be to some. Thanks in advance Link to comment Share on other sites More sharing options...
shao_khan Posted June 16, 2007 Report Share Posted June 16, 2007 TO be honest having had bus rides around some of the Egypt roads, I'd go for standard suspension with 17's, I wouldnt do anything to firm the ride up at all. 18's afterall can be purchased aftermarket if you feel you can live with them or as a luxury, but would be nothign worse than knowing you need to buy smaller wheels. Link to comment Share on other sites More sharing options...
hmetwally Posted June 17, 2007 Author Report Share Posted June 17, 2007 Thanks for that. What about the ride quality overall for the TT? Non of the reviews talk much about the comfort. I may go for the 17s as you highlighted, and yes bus rides should be avoided whenever possible on that side of the hill Link to comment Share on other sites More sharing options...
Merlot Posted June 17, 2007 Report Share Posted June 17, 2007 Stick with the 17" and spend the £ on magnetic ride. Link to comment Share on other sites More sharing options...
NUM_TT Posted June 18, 2007 Report Share Posted June 18, 2007 [ QUOTE ] Stick with the 17" and spend the £ on magnetic ride. [/ QUOTE ] Agreed I understand that the magnetic ride is more comfortable (in non sport mode) than standard suspension. Link to comment Share on other sites More sharing options...
ChadW Posted June 18, 2007 Report Share Posted June 18, 2007 Not sure about the new TT but my first TT had Quattro suspension and 18s yet seemed to be the same sort of ride cormfort as my current 2001 TT with Std suspension and 17s. Link to comment Share on other sites More sharing options...
hmetwally Posted June 24, 2007 Author Report Share Posted June 24, 2007 What about run flats? Does it affect the ride quality? And if one goes without run flats? what do you do without a spare? Link to comment Share on other sites More sharing options...
vagman Posted June 24, 2007 Report Share Posted June 24, 2007 I have a mkII 3.2 with 19" wheels and magnetic ride. With Mag Ride set to Sport, the ride is firm, but not crashy and rough in the way that the mkI was. It is a superb piece of kit and noticeably improves handling when driving hard down twisty country roads. Link to comment Share on other sites More sharing options...
hmetwally Posted July 13, 2007 Author Report Share Posted July 13, 2007 Hi, Thanks for all the responses. I just got the car and I want to get some views on the tyre noise. They seem to be quite noisy on the road, is this normal? Would a tyre change fix the problem or is this the way it is on Coupe TT's MK II? The tyres are 17' 245 Bridge Stone Potenza run flats. Link to comment Share on other sites More sharing options...
shao_khan Posted July 13, 2007 Report Share Posted July 13, 2007 Hi, THe run flats always seem to be a little noisier to me. Also I have noticed that tyres from the factory always seem to be a slightly harder compund which does make them slightly noisier also. My S3 has contis and they are fairly noisey as well. Link to comment Share on other sites More sharing options...
MK1_TT Posted July 14, 2007 Report Share Posted July 14, 2007 Some great info to help select tyres (whatever your preference) here... great info! Link to comment Share on other sites More sharing options...
CarMad Posted July 16, 2007 Report Share Posted July 16, 2007 Great link thanks. Link to comment Share on other sites More sharing options...
hmetwally Posted July 18, 2007 Author Report Share Posted July 18, 2007 I have changed the tyres to Goodyear Eagle F1 and hurraahh. These are much better. The noise has substantially improved. But now I do not have anything to protect from a tyre puncture (The previous ones were run flats). Does a can of goo work well? Link to comment Share on other sites More sharing options...
Mook Posted July 18, 2007 Report Share Posted July 18, 2007 Don't use that goo stuff - it's evil. Shags the tyre (some tyres can be repaired after a puncture, as long as the puncture isn't in the sidewall or within - IIRC - 25mm of the sidewall on the main tread) and your alloys won't thank you for it. Link to comment Share on other sites More sharing options...
