Is it ok to mix longlife and standard oil?
Wobby
Was away recently and checked my oil and water, low on both!!
Found a local Halfords but couldn't find the correct spec oil for a 10k serviced car (PD130). Had a choice beween good quality wrong spec or the longlife stuff. So i went for longlife, bought a litre and put it in.
Will this cause any problems? Oil is due changing either this weekend or next weekend so it wont be in long. It was Castrol Edge that i used. Is there a Castrol product for the PD engine on standard service intervals?
