darrentomlinson Posted July 11, 2007 Report Share Posted July 11, 2007 bought a 350i clutch master cylinder was stuck all the way out, replaced it and pipe, master cylinder then popped the thrust pin over the arm, fixed it, drove 30 miles, now the arm seems stuck all the way in with no cluth, anybody had this before? when driving the clutch would get/feel soggy to press, and the gears got tight, the day after all seemed fine, just about got it home as the gears would not select anymore, removed slave cyl today and the arm inside is right at the back, any ideas welcome, its an 84 rover v8 , wedge tvr 350i thanks in advance. Link to comment Share on other sites More sharing options...
darrentomlinson Posted July 11, 2007 Author Report Share Posted July 11, 2007 sorry meant to say slave cyl pooped the thrust pin over the clutch arm Link to comment Share on other sites More sharing options...
