BPT Posted July 27, 2007 Report Share Posted July 27, 2007 Hi guys, I've had my S3 nearly 2 years, and in that time have managed to break both seat release levers on the passanger side Recaro seat. This obviously makes it quite tricky to get people in the back! The levers are quite flimsy and when the back seats are folded flat against the front seats, are not 'man' enough to release the hinge to flip them forward. Anyway, in a nutshell I need to repair it, but don't know if you can just get hold of this small part, or how big a job it might be to replace them. Any ideas....? Link to comment Share on other sites More sharing options...
davidhodgkinson Posted July 27, 2007 Report Share Posted July 27, 2007 They both just pull off straight backwards towards the rear of the car... Link to comment Share on other sites More sharing options...
steve1975l Posted July 27, 2007 Report Share Posted July 27, 2007 Nearly broke mine too. I used a lot of grease and it works fine now. My rear seat wouldn't fold down last week. Eventually it went down but it felt like it was breaking. A good grease everywhere and it is OK now. Did the seat runners as well and they slide a lot better. Go mad with the grease saves the hassle later. Link to comment Share on other sites More sharing options...
s3geezer Posted July 28, 2007 Report Share Posted July 28, 2007 It's no biggy. It happened on my S3. When my car went in for a service (at Audi) they fixed it in like 10 minutes. It's really common and the part costs like £10 so you're ok. It's probably an easy fix job yourself but I don't fancy taking my seat apart. For the sake of the £20 Audi charged in total I felt it wasn't worth it. Link to comment Share on other sites More sharing options...
steve1975l Posted July 28, 2007 Report Share Posted July 28, 2007 By the time you have driven down there it must be easier to change it yourself if the stealer only charged £10. Link to comment Share on other sites More sharing options...
s3geezer Posted July 29, 2007 Report Share Posted July 29, 2007 Yeah I agree but the car was having a service so I said "fix the seat lever at the same time please". Link to comment Share on other sites More sharing options...
blackspear Posted August 2, 2007 Report Share Posted August 2, 2007 Hi, Did any of you guys attempt to remove the fornt seat, I ma having a problem wiht hte seat sticking on the rails, but before removing & resolving I want to ensure the side airbag in the seat will not go off on me.... Thanks in advance Link to comment Share on other sites More sharing options...
steve1975l Posted August 2, 2007 Report Share Posted August 2, 2007 Some info here. http://myweb.tiscali.co.uk/macnee/home.htm Link to comment Share on other sites More sharing options...
BPT Posted August 2, 2007 Author Report Share Posted August 2, 2007 Thanks a lot guys, davidhodgkinson was right; they pull off really easily with a pair of pin nose pliers . No amount of Araldite was going to repair the old one . £4.79 each from the stealers seems reasonable-ish , although they aren't stocked so have to come from Germany . I'm surpried as they are pretty flimsy and must break all the time. If anyone else is wondering, they are left and right handed, with one of each per seat. Thanks for your help guys. Link to comment Share on other sites More sharing options...
Jimbob_S3 Posted August 7, 2007 Report Share Posted August 7, 2007 Hi, My rear seat wont release on my 2001 S3.. The lever just doesn't quite pull far enough to release the catch, I have to use a screwdriver through back of seat to lift the catch... Anyone ever done this repair and is it easy? Cheers. Link to comment Share on other sites More sharing options...
