[Audi A3/S3] Needle sweep on startup on new S3
AZURES3
I'm not even sure I like it as it looks to the uninitiated like there's an electrical fault on the dials when the needles suddenly ping over smashfreakB.gif
Mine doesn't look like an electrical fault!
Used to get this effect on my old Fords when a resistor went in the instrument pod!
That's odd, because the clutch press requirement was new functionality for MY2008. Not sure why you don't have the dials option. ECU patch could easily add the sweep function.
Dont believe there is such a thing as a 2007 model year for the S3 to be honest so maybe the ECY patch will fix it 169144-ok.gif
AZ
If you don't believe that there was a distinct '07 model year for the S3, the "7" in your VIN might help to convince you (10th character, I believe). I deliberately waited until June for my car to make sure it was an '08 MY. Sure enough, it has an "8" in the VIN.
Fair point, with all that has been going on in my life I forgot we are over half way throught 2007 smashfreakB.gif
Blimey my car will be a year old in 4 months !
AZ
grin.gif I remember a friends Focus had a dodgy battery and it did that needle sweep continuously when you put the key in the ignition. I may have made a comment about that being the only time he'd see 140 on that speedo. tongue.gif
AZ
I just read a review of the new A5 and the reviewer comments that the two main intruments, speedometer and tachometer, have a new feature "When you switch on the engine, both the needles whiz round to the full extent and then drop back to zero"
Thanks Sparky
John, for me to turn on/off the sweep, I do the following:
DIS Menu > Set > Indications > Dials (tick/untick).
Well I've had a good look around in the DIS and can't find any mention of dials under the set menu. It could be a vagcom job or just not possible.
Regards, John.
Thanks Sparky
Regards, John.
beerchug.gif John
AZ
  • 1 year later...
